evnrude 150 1995 starved for gas
joe7875
need help!!!i have a 1995 evinrude 150 motor runs sweet for 5 to 10 minutes then i have to pump the priming bulb and it comes back to life.i have changed the fuel tank pickup the vro fuel pump still same problem .can anyone help!!
I had a similar problem with an inboard. It was the fuel pump. Heck, I don't even know if outboards have a fuel pump? :confused:
joe7875
hey doc thank you will try that again this is the second fuel pump the first one could have been falty!!here we go again
Kewl. Good luck.
You can get a tool to measure fuel pressure, so that you do not replace a good fuel pump. Might save you some work if the fuel pump is not bad.
Bt Doctur
Yamaha`s have 2 fuel pumps, Doc.
You run from a portable tank or inhull type.?
might be a anti-syphon at the tank thats clogged a bit.
