We must be having a good time because no one has posted any issues.
hopefully were doing the required maintance on our boats and are not having issues.
Have a Safe Year.:a7::a7::a7::a7::a7:
I do have a buddy with a 99 crown line 22ft. for a while now he has an issue when taking off. The boat will cut out. No amount of pumping will save it. He has to stop and start over. 50 / 50 chance it will take off okay next time or fail again.
His is an MPI. He has just had all the injectors cleaned but still having the issue. He puts seafoam in with every fill up but is going to try stabil now. He had his mechanic (same one I've used) check it out and still he cannot figure out the issue. they try this and that but so far nothing they have tried has solved the problem.
Doc, I know it's been a while since you posted this, but I had a similar problem in my I/O, and on my tractor. Both problems turned out to be bad coils.
Interesting Bob. I'll pass that along to my friend and keep you posted if that makes a difference. I doubt he can test it thoroughly until next season though.
