1987 yamaha pro-v WHAT IS A GOOD TUNE UP
I would start with a compression test first and new plugs. Dosent sound bad on start up but appears to be a bit rich with the oil mixture.Do you mix the oil or is it oil injected?
mcgill
THANK YOU
FOR YOUR HELP ,,,,I WAS TESTTING THE COILS ONE DAY AFTER THE VIDEIO AND I FOUND 2 BAD COILS WILL THIS STOP IT FROM RUNNING THE RIGHT WAY
