Go Back   Net Boat Talk > General discussion > Classifieds For Sale & Wanted > RSS Classifieds
Old 03-12-2010, 05:54 PM
RSS_user RSS_user is offline
Senior Member
RSS_user is on a distinguished road
Default Trojan 11 Meter International Express Cruiser
Posted by: riverjohn1
Description: LOCATION: Harrison Twp. Michigan REGISTRY NO.: MC 0271 LV VESSEL TYPE: 11 Meter International Express Model 370 (37'-6' waterline)YEAR: 1984BUILDER: Trojan International Yachts HULL NO.: TJWDO04883 84LENGTH: 37'6" BEAM: 14'3" DRAFT: 3'3" Est. Wt. 16,800 lbs dryHULL TYPE: Modified V Hard Chine FASTENINGS: Bronze & S.S.CONSTRUCTION: Fiberglass Reinforced Plastic (Cored) Frames Fiberglass Reinforced Plastic Bulkheads Fiberglass Encapsulate Hull built by BretamDECKS: Fiberglass Reinforced Plastic (Cored) ENGINES : Two (2) V-8 Thermo Electron Crusader Gasoline 454 CID W/Borg 2.91:1 Reduction Gears Serial No.; Port 40950 450 Hours (approx) Serial No.; Stbd. 40918 450 Hours (approx) Engines are equipped with approved type flame arresters.IGNITION : Full electronic new 2005SHAFTS: Stainless Steel 1-7/8 Diameter FUEL SYSTEM: One (1) rectangular aluminum 350 gal. Capacity tank vented overboard, located in bilge beneath aft deck. All fittings are on top of tank. Feed & breather lines are approved Aeroquip fuel linesVENTILATION: Complies with Federal & USCG~Regulations.AUXILIARIES: Onan 6.5 KW Gasoline Generator & Muffler.BILGE PUMP: Three (3) Rule 12 VDC automatic pumps.FIRE EXTINGUISHING: Fireboy 70 CG Automatic Halon & One (1) 2~ lb. B-C Dry Chemical Fire ExtinguishersELECTRICAL SYSTEM: Vessel's system is 12 volt DC & 110 VAC. Also wired for 110 VAC Shore power with Circuit Breakers. ACCOMMODATIONS: Sleeps 6. Wrap-around dinette converts to bed. Forward stateroom with vanity and sink. Seat on port side of salon converts to bunk beds.GALLEY: Contains Princess 2 burner 110; VAC range recessed. Frigidaire Microwave oven. Formica counter tops. Double"S.S sink. Sub Zero 110 VAC Refrigerator& freezer with ice maker. HEAD: Enclosed compartment containing sink, shower, exhaust fan, vanity and Mansfield 12 VDC electric unit with holding TankWATER SYSTEM: Est. 100 gal. cap. Fresh Water Tank, 17 gal. Hot Water Tank & pressure pump.GROUND TACKLE: Danforth S1600 with 200' Nylon Rode 5/8" & electric windlassNAV. EQUIP. & ACCESSORIES: VHF radiotelephone with antenna & accessories.Radar Arch. Antenna & bracket Garmin Global Positioning System.Autohelm Digital Depth Sounder.Aqua Meter Saturn Magnetic Compass.Guest Judson Micro Synchronizer.Boat Leveler Hydraulic Trim Tabs.Ray Line Remote Searchlight.Electric Windshield Vent Openers.Three (3) 12 VDC Windshield Wipers.Dual Trumpet Air Horn.Professional Mariner 35 AMP Battery Charger.Three (3) 12 VDC Batteries.Cetck Benmar 210 Auto Pilot.Cetek Benmar Loran C Interface.Brisson Gas Vapor Alarm.Cockpit Refreshment Center W/Sink & Pressure Water.Cockpit refrigerator with freezer.Deck rinse down.Clarion marine stereo with hard wired remoteClarion DCZ 625 6 Disc Player.NAV EQUIP. & ACCESSORIES CONT: Sony XM604M 600 Watt amplifier.Cruisar Reverse Cycle Air Conditioner.Good 12 VDC Anchor Windlass.Fiberglass & Teak Bow Pulpit W/Anchor Roller.Teak & stainless swim ladder.Fiberglass Swim platform.TV digital converter box with digital
Boat Loans By Excel Credit.
More...
