2021 Chaparral 21ssi Battery Diagram
ClassicTronTime
Howdy all,
I recently bought a 2021 21SSi and pulled the battery to charge it. Unfortunately I didn't pay close attention to cables were on which terminals and they are not harnessed together super clearly... Is anyone familiar with which terminal the wires go to? Honestly my big Q is on the two yellow cables. One runs to the battery switch and the other runs to the engine. When I initially connected it, I had a yellow on each terminal.. the boat started but I had no accessories. I swapped the yellows and the accessories worked, but I had now power to the engine. Are both yellows supposed to be on the positive terminal??
If anyone is familiar with this boat and can weigh in or share a picture I would greatly appreciate it!!!
Thanks,
P
In boating, yellow is negative. Why? As not to be confused with 120V A.C. which is black. You mentioned that "One runs to the battery switch". Are you sure? Since it yellow, I would thing not. Only red wires should be going to the battery switch. Thats not to say that some one changes the wires? So be sure!
There is a book by Nigel Calder on boat wiring and a lot more. Very good reading!
Some boaters use wire ties and bundle the cables before removing them from the batteries.
