Shore power voltage indicator gauges
110 Volt Gauges
Has anyone found a replacement or a fix for these gauges. Shore power works but the voltage is not displayed. Figure it must be a common issue seeing as both of mine are non functional.
Have you opened it up and checked the wiring? I could be wrong, but I would check the neutral wire to the gauges first. Due to the fact, that both 120V meters are not working.
If you want to upgrade, Blue Sea System has some very nice digital gauges.
Thanks , good point and I will check out those Replacements
The more I am thinking about it, both meters should have separate naturals. if I am seeing the panel right, one meter is for cord #1 and the other cord #2. Yes? But I don't know how its really wired. My boat, both cords are total separate.
