Here`s a tip if you have these types of problems.
Assuming the starter itself if functional
no crank,no power:
jump out the starter solenoid,if it cranks you have a good battery connection.if it dosent crank check ALL the battery connection points INCLUDING the negative cable at the block.
Locate the slave solenoid, jump it out.if the starter operates you have power thru the main breaker. Further tracing is necessary.Main harness connectors, ign. fuse, ign. switch,main neg. return wire.
REMEMBER ,you need 2 wires/feeds to make something work, A Positive and a Negative connection.
no crank,no power:
