Bt Doctur Super Moderator Staff member May 7, 2022 #1 An overlooked item is the water inlet hose from the outdrive. It can kink and restrict flow. On Bravo `s its called "Bravoitis" where the internal fitting is crushed closed by corrosion.
Denny Well-known member Gold Site Supporter May 7, 2022 #2 They cured that on the Alpha 1's They made a hose with a bend in it. Maybe they will do that for the Bravo's
