LtColMac17
I’ve been troubleshooting this problem after changing the outdrive oil. I’ve disconnected the shift cable at the shifter, no problem with the teleflex shifter. Throttle operates fine. I’ve disconnected the cable at the outdrive, and the drive shifts fine forward and reverse with proper lockup felt at the props in both positions. I’ve also tried shifting with engine running on the hose - froze solid.
Have I done everything I can, short of replacing the shift cable? I haven’t been in the water this season and it ran fine last October.
