1999 Chaparral 2135 SS
J L Garrett
Had a problem yesterday. My Throttle, a Quicksilver 3000 Classic, won't shift out of neutral to forward or reverse. I pulled of panel, and cables are working. Seems that the advance button isn't re-engaging. Anyone have that type of problems or have a suggestion? Not sure if I need to replace the whole Throttle?
I had a 89 Force 230 Baja with the Quicksilver Throttle. Similar issue and I had to replace the whole throttle. It's been over 20 years ago so my memory of the details is rather fuzzy but your situation sounds very similar. Good luck.
I am presently going through the same issue with my 1985. All cables are perfect, there is what is called a momentary switch, that when you shift from N to F to R and so on, it kills the engine for a split second to release the pressure. That was my issue. Start there.
How does it shift if the engine is not running?
As I've stated here many times, my Alpha One and the shifter do not like rapid shifting between Forward, Neutral and Reverse. With the new slip that I had this season, it caused me to shift quickly to keep control of the boat. It didn't take long for the shifter to start sliding around and not clunking into gear. Since then, I've changed to a new slip that requires much less shifting and so far, it's holding together. But, I feel that I'm very close to losing Reverse. I'm nursing this along as much as possible because if I have to take it to the mechanic, I'll be out of the water for several weeks.
I don't know if your shifter is nearly the same as mine but many times, as i'm moving the shifter, I have to pull the shifter up as I'm moving the shifter forward or reverse or back into neutral. For some reason or another, lifting it a little bit seems to help.
Dan, it sounds like you need to take off the cover on the shifter and tighten the 4 screws that hold it down, it should not slide around.
The whole shifter assembly is still properly attached to the boat frame. The word sliding is meant to mean the throttle handle is moving freely and not clicking into place and no change in the outdrive. For example, If the outdrive is in reverse and the throttle handle is moved to neutral or forward, it still remains in reverse. The throttle handle "slides" over N and F. If literally feels like its sliding as it skips over N and F.
When I said "pull the shifter up" what I meant was: To apply upward pressure on the throttle handle while you're shifting into F, N or R. It doesn't mean lifting the whole throttle assembly. The upward pressure on the throttle handle, for me anyways, helps keep it working properly. Been like this for nearly 15 years.
I think that we have the same shifter. On the front of the cover there is a small black button, if you push it in it will let you lift the cover off. Inside on the top is a ball bearing with a spring loaded tension set screw to adjust the tension on the ball bearing.There is a plate that is attached to the shifter handle. It has 3 slots in it. As you move the handle from F-N-R respectively the ball bearing will fall into one of the slots and hold the shifter there. If I read you right, it sounds to me that the bearing is not engaging properly.
Just about ready to shift out into Lake Erie. Here’s a pic of my throttle. Neutral
That looks normal. Are you saying that when you shift into N it does not lock into place?
