2006 Sunesta 236 I want to replace the gauges
chriscarlos
I need to replace the gauges on my Sunesta and I'm curious if anyone else has done this and if so, did they use original gauges or repleacement? If the gauges were not original, did you also replace the sending units? Does anyone know if Chaparral still sells replacement gauges?
Thanks
Thanks
Try Cecil Marine
Most gauges are off the shelf stuff. You just need to match the specs of the old to new. I will use fuel a gauge as an example. Some are rated 0-30ohms or 0-90ohms. Some have a switches to match the sending unit. It really depends on what you pick.
Do you have analog or digital? Around 2010, chap went digital which opens a whole new world on reading the data. Phone, laptop, GPS, and more
