Bomar Porthole screen replacement
How do you identify the model number of the Porthole? I want to replace the screen. Bomar has 615 and 618, how can you determine which one you have. Is the 15 and 18 the lenght?
No , in retrospect I guess I should have, I suspect the 6 is the series of stainless and the subsequent number is the length. Too bad the boat is soooo far away.
Cheers
You might try calling Cecil Marine with the year and model, they may be able to help, using just that, or tell you what info you need.
It is a sublet item, someone made it for Chap, see if there is a name or something stamped on it.
Was at the boat today and took these measurements.
