What could be the leak ? Thanks Leak into bilge
Phillbo Well-known member May 20, 2022 #3 Does it leak when sitting still or only when the motor is running?
Doc Liquid Addiction Staff member May 23, 2022 #4 Iggy said: Is it sea water or water from the holding tank? Click to expand... It does look clear like it might be from holding tank.
C Chap264 New member May 24, 2022 #5 It could be outside water coming in from the transom or thru hulls or from the engine cooling system or the onboard water system. Need to do some more diagnostics.
D dgiles New member May 25, 2022 #6 It isn't the thru hulls or holding tank or from the running engine. The video clearly shows it leaking under the transom while the motor is off.
chappypete New member Jun 7, 2022 #9 Transom assembly needs to be replaced if it’s leaking while just sitting in the water
chappypete New member Jun 8, 2022 #10 Actually after looking at the video more closely it’s not the transom Assy Gotta be one of your hoses or bellows coming from the drive.
