Steering wheel bolt pattern
Does anyone know the bolt pattern? Is it a standard auto bolt pattern. I want to replace the standard wheel in my 350.
You should be able to pop off the center cap and it will give you the answer.
Not sure about the new autos, but the old ones were held on with one nut.
When I changed mine, there were 6 or 8 allen screws holding it on.
Try Cecil Marine they may have the answer.
Google this, it will either help or confuse you more.
(boat steering wheel bolt patterns)
Cool thanks, now if I had the center to center distance I could figure out the pitch circle. Heading to boat this weekend. I will update this post later as it might be useful for someone.
It appeared to be 1", unless it's metric. If you need it sooner, I'll be there again tomorrow.
Thanks much appreciated, wife said I can't get the wheel just yet 😉. We are taking a month to drive her home and I will probably replace this winter.
Reactions: ags
You normally loosen the nut, slightly pull upward and strike the nut to remove the wheel from the tapered shaft
